Suggestion for a feature - split button with a preset split for 2nd slice
Simon Lewis
Simon Lewis Member ✭✭
edited June 2020 in New Ideas
As a DX op sometimes I need to be really quick setting a split .. idea would be a one hit button that you can hit that sets a slice up at a predetermined split - ie slice A is on 14.020 and I have an instant split button with a preset offset of +1, +2, +5 etc all ready set - to go split I hit SPLIT button and its automatically sets up a 2nd slice +1,2 or 5 up (or down if programmed) and sets slice A as TX - my 590 takes me a second or 2 to set a split and sometimes even thats too long when the DX says UP 2 :)
2 votes
In Review · Last Updated
  • Paul Christensen, W9AC
    Paul Christensen, W9AC Member ✭✭
    edited July 2017
    DDUTil does this. What it does not do yet is set audio balance to place DX left and calling freq. slice right, or some balance in between.
    Paul, W9AC
  • Simon Lewis
    edited April 2015
    I guessed it would .. but I meant natively :)
  • James Kennedy-WU5E
    James Kennedy-WU5E Member ✭✭✭
    edited June 2020
    IF YOU SELECT +RX it automatically jump up 5
    fellow DX'er
    WU5E
  • Jim K4JAF
    Jim K4JAF Member ✭✭
    edited January 2018
    As stated earlier DDUTIL allows you to set up split buttons for whatever split you want.  Also the DD6AUP command in DDUTIL allows you to set the balance of audio between the right and left speakers.  Jim K4JAF
  • LB2EG_Richard
    LB2EG_Richard Member
    edited April 2015
    In DDUTIL I have assigned a macro to one FlexControl button, to make split +1 and put slice A on left ear and slice B on right ear. And another macro to remove slice B and restore audio balance:
    Split on:  DD6SPL01;DD6AUP0:000;DD6AUP1:100;
    Split off: DD6AUP0:050;DD6AUP1:050;DD6SSX0;DD6SRV1;
    It works very well.
    LB2EG Richard
  • Carl Moreschi
    Carl Moreschi Member
    edited April 2015
    My N4PY Pegasus Plus has exactly this function using the Flex Control buttons.  There is an "UP 1" and an "UP 5" button selection.  And you can press them multiple times to add more to the split.  With split off, pressing UP 1, sets VFO B to VFO A +1 and makes VFO B the TX slice.  Each additional press of UP 1 adds one more to VFO B.
