Typo in panadapter.cs (flexlib)
rfoust
Found a typo, I think RaisePropertyChanged should be RFGainStep instead of RFGainHigh in the snippet below:
private double _rf_gain_step; public double RFGainStep { get { return _rf_gain_step; } set { if (_rf_gain_step != value) { _rf_gain_step = value; RaisePropertyChanged("RFGainHigh"); } } }
It is a typo. Good catch! We'll get it fixed. Thanks.2
For reference, this is issue #1821.0
<total aside>
Can I just chime-in with some unsolicited advice? These names of the properties (the argument to RaisePropertyChanged) would ideally be constants, and not require the dev to type-in a string literal at each invocation. Eliminates any chance of typos making it into the released code. Also, it they were scoped correctly, the consumer of the API could use the same constants when consuming the events.
Sorry, it's the dev manager in me...
</total aside>
I agree with you and had the same concerns when we started using the ObservableObject class (which uses the INotifyProperty interface). This is the industry standard for binding WPF GUI components to C# libraries (see https://msdn.microsoft.com/en-us/library/system.componentmodel.inotifypropertychanged%28v=vs.110%29....). Aside from the string issue, it has really worked pretty well.0
As someone not familiar with dot net programming and C sharp, why not use a string constant and refactor the constants into a header file?0
Again, the INotifyProperty interface which uses the string based propertyName variables is the industry standard way of binding WPF GUI components to C# libraries -- especially if using the Model View ViewModel (MVVM) framework. I, personally, would rather take my licks with the standard that thousands of other developers are using rather than trying to roll my own and not have the support and documentation of millions of lines of code from which others have already learned.1
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
