Typo in panadapter.cs (flexlib)
rfoust
rfoust Member ✭✭
edited June 2020 in SmartSDR API
Found a typo, I think RaisePropertyChanged should be RFGainStep instead of RFGainHigh  in the snippet below:
private double _rf_gain_step;          public double RFGainStep          {              get { return _rf_gain_step; }              set              {                  if (_rf_gain_step != value)                  {                      _rf_gain_step = value;                      RaisePropertyChanged("RFGainHigh");                  }              }          }
    edited March 2017
    It is a typo.  Good catch!  We'll get it fixed.  Thanks.
  • Eric-KE5DTO
    edited February 2017
    For reference, this is issue #1821.
  • Peter K1PGV
    Peter K1PGV Member ✭✭✭
    <total aside>
    Can I just chime-in with some unsolicited advice? These names of the properties (the argument to RaisePropertyChanged) would ideally be constants, and not require the dev to type-in a string literal at each invocation. Eliminates any chance of typos making it into the released code.  Also, it they were scoped correctly, the consumer of the API could use the same constants when consuming the events.
    Sorry, it's the dev manager in me...
    </total aside>
  • Eric-KE5DTO
    edited February 2020
    I agree with you and had the same concerns when we started using the ObservableObject class (which uses the INotifyProperty interface).  This is the industry standard for binding WPF GUI components to C# libraries (see https://msdn.microsoft.com/en-us/library/system.componentmodel.inotifypropertychanged%28v=vs.110%29....).  Aside from the string issue, it has really worked pretty well.
  • Mark Erbaugh
    Mark Erbaugh Member ✭✭
    edited March 2015
    As someone not familiar with dot net programming and C sharp, why not use a string constant and refactor the constants into a header file?
  • Eric-KE5DTO
    Again, the INotifyProperty interface which uses the string based propertyName variables is the industry standard way of binding WPF GUI components to C# libraries -- especially if using the Model View ViewModel (MVVM) framework.  I, personally, would rather take my licks with the standard that thousands of other developers are using rather than trying to roll my own and not have the support and documentation of millions of lines of code from which others have already learned.
