Profiles/Memories - when to use each.
Tom Warren
Tom Warren Member ✭✭
   We, the Community,  have talked about 'Profiles' and then talked about 'Memories' but I wonder why FRS gave us both. It seems to me that they might be combined into 1 storage area.
   It would be interesting to hear some thoughts on that idea.
I also have a question; Is it possible to backup the 'Memories' data?  I didn't see any reference to that procedure in the manual.
Tom W4TMW
  • rfoust
    rfoust Member ✭✭
    edited May 2019
    You can perform a backup of the memory data by going to the Profile menu, then select "Import/Export Profiles" and be sure to select "Memory" on the export tab.  Click the "Export" button and select a location on your hard drive to save it.
  • Norm - W7CK
    Norm - W7CK Member ✭✭
    edited May 2019
    PROFILES:
    I have several profile setup on my 6700.  An example of one would be "40m Nets".  This profile has 4 different slices defined across the 40m band.  They are nets or frequencies that I tend to hang out on on a regular basis.  I also have other profiles that have 4 different panadapters and all 8 slices defined.  This includes a few frequencies on the 2 and 6 meter bands.  I tend to use this profile to watch for band openings.
    MEMORIES:
    Say I have my 40m Nets profile up and running and I want to hop onto 20 meters but don't want to loose my 4 slices I currently have up and running on 40m.  I open a panadapter, select 20 meters, open a slice and make it active.  Then I go into my memories and select what ever frequency I want to listen to.  I can click on any frequency in my memory list.  Works great and doesn't clobber my "40m Nets" profile I also have running.
    Hope that helps!
  • Tom Warren
    edited March 2015
    Robbie,
    I've taken note of that and thanks for the explanation.....so we have to go to 'Profile' menu to save 'Memory'....interesting.  Tom W4TMW
  • Tom Warren
    edited March 2015
    Norm,
      After I set up some data in 'Memories' and started using it, it just seemed to me that I could use "Memories' for everything and have more room to add descriptions as an added benefit and discard the use of 'Profiles'. But your scenario is interesting, thanks.  Tom W4TMW
