Profiles/Memories - when to use each.
Tom Warren
We, the Community, have talked about 'Profiles' and then talked about 'Memories' but I wonder why FRS gave us both. It seems to me that they might be combined into 1 storage area.
It would be interesting to hear some thoughts on that idea.
I also have a question; Is it possible to backup the 'Memories' data? I didn't see any reference to that procedure in the manual.
Tom W4TMW
Tom W4TMW
You can perform a backup of the memory data by going to the Profile menu, then select "Import/Export Profiles" and be sure to select "Memory" on the export tab. Click the "Export" button and select a location on your hard drive to save it.0
PROFILES:
I have several profile setup on my 6700. An example of one would be "40m Nets". This profile has 4 different slices defined across the 40m band. They are nets or frequencies that I tend to hang out on on a regular basis. I also have other profiles that have 4 different panadapters and all 8 slices defined. This includes a few frequencies on the 2 and 6 meter bands. I tend to use this profile to watch for band openings.
MEMORIES:
Say I have my 40m Nets profile up and running and I want to hop onto 20 meters but don't want to loose my 4 slices I currently have up and running on 40m. I open a panadapter, select 20 meters, open a slice and make it active. Then I go into my memories and select what ever frequency I want to listen to. I can click on any frequency in my memory list. Works great and doesn't clobber my "40m Nets" profile I also have running.
Hope that helps!
Robbie,
I've taken note of that and thanks for the explanation.....so we have to go to 'Profile' menu to save 'Memory'....interesting. Tom W4TMW0 -
Norm,
After I set up some data in 'Memories' and started using it, it just seemed to me that I could use "Memories' for everything and have more room to add descriptions as an added benefit and discard the use of 'Profiles'. But your scenario is interesting, thanks. Tom W4TMW0
- 690 The Flea Market
- 197 SmartSDR+
- 461 SmartSDR for Mac
- 112 Aurora
- 976 Genius Products
- 483 Power Genius XL Amplifier
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
