DAX switches to TX disabled in Parallels
DonS
Member ✭✭✭
I just upgraded to v1.4 release of SSDR in Parallels VM. Everything appeared to be working. I started fldigi and I was receiving psk signals without a problem, however, when I put fldigi in transmit I got nothing out and almost immediately in the DAX control panel a message popped up saying "TX disabled". I have attached pictures of the DAC Control Panel showing RX and TX. Wonder what I am missing? On my Windows PC it works ok using the same setup. I should add I had no issues prior to this when I was running Parallels.
Don - kx9q
Don - kx9q
That is because TX is disabled in DAX. Click the TX next to channel 1 to enable transmit on that DAX channel.0
Thanks Tim. Never thought about that as I didn't think TX was a button like the channel indicator - CRS affliction I guess! Maybe I should also RTFM sooner rather than later :-)
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 171 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 248 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 193 FLEX-8000 Signature Series
- 915 Maestro
- 887 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 742 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 957 Third-Party Software
