DAX switches to TX disabled in Parallels
DonS
DonS Member ✭✭✭
edited January 2020 in FLEX-6000 Signature Series
I just upgraded to v1.4 release of SSDR in Parallels VM.  Everything appeared to be working.  I started fldigi and I was receiving psk signals without a problem, however, when I put fldigi in transmit I got nothing out and almost immediately in the DAX control panel a message popped up saying "TX disabled".  I have attached pictures of the DAC Control Panel showing RX and TX.  Wonder what I am missing?  On my Windows PC it works ok using the same setup.  I should add I had no issues prior to this when I was running Parallels.
Don - kx9q
    edited March 2017
    That is because TX is disabled in DAX.  Click the TX next to channel 1 to enable transmit on that DAX channel.
  • DonS
    DonS Member ✭✭✭
    edited January 2020
    Thanks Tim.  Never thought about that as I didn't think TX was a button like the channel indicator - CRS affliction I guess!  Maybe I should also RTFM sooner rather than later  :-)
