DAX switches to TX disabled in Parallels
DonS
Member ✭✭✭
I just upgraded to v1.4 release of SSDR in Parallels VM. Everything appeared to be working. I started fldigi and I was receiving psk signals without a problem, however, when I put fldigi in transmit I got nothing out and almost immediately in the DAX control panel a message popped up saying "TX disabled". I have attached pictures of the DAC Control Panel showing RX and TX. Wonder what I am missing? On my Windows PC it works ok using the same setup. I should add I had no issues prior to this when I was running Parallels.
Don - kx9q
Don - kx9q
That is because TX is disabled in DAX. Click the TX next to channel 1 to enable transmit on that DAX channel.0
Thanks Tim. Never thought about that as I didn't think TX was a button like the channel indicator - CRS affliction I guess! Maybe I should also RTFM sooner rather than later :-)
- 197 SmartSDR+
- 110 Aurora
- 322 Shack Infrastructure
- 227 Networking
