Question: FM mode - no TX
It was very late last night when I finally got a chance to install v1.4 so I didn't have much time to tinker around with FM but attempted a quick test of that mode.
Since the upper bands were closed and there aren't any local repeaters, I was trying to copy (simplex) with a 3-band HT. I copied the carrier, but absolutely no voice info, nor could I see a reaction to my voice in the transmit envelope on SSDR (shouldn't I see the envelope spread?). However, I copied when switched to another mode e.g., USB.
Is there a setting I missed for FM that blocked my Tx audio?
As you write about a 3-band HT I deduce that you have a 6700 and transmitted on 2 meters. Have you tried NFM? I have a 6500 and NFM on 10 meters works well.0
Tried NFM, as well. I've also got a 6500 trying to transmit on 10m. The HT is my son's Kenwood F6A that he insists has FM on 10m. It seemed to me to be working because I heard the carrier - just no audio. We switched to USB (everything else the same), and it copied fine.
Alex, do you see a reaction in the envelope when you speak?
Try cold boating the radio and resetting the radio to factory defaults.0
Will do, tonight, Tim. Thanks.0
I was able to run 146.34/94 NFM Remote with my 6700 Last night
with no problems....
Sure is easy to program the Repeater options required and Freq offset
with the Flex. I never could remember how to program my Icom without
the book....
Thanks Flex
Ken W9IE0 -
Yeah, I did see and hear a normal FM signal on my IC-756PRO scope.0
Tim,
FM is working, now. I really didn't have to do anything to fix it. I turned on the radio and decided to test it before doing a factory reset, and it just worked. That's good enough for me, issue resolved. Thanks.
That is good news!0
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
