How to set up Pixel RF PRO-1B receive loop with Flex-6700 and KPA500 amp
Mike_N1MD
Santa came early and left a Pixel receive antenna under the tree. I have become disoriented while trying to make the connections to the antenna and Power Inserter to my Flex-6700 and amplifier. I think I want to put the receive antenna on RX-B with my transmit on ANT-A. The relay cables from the power inserter to radio and amp have particularly confused me.
Anyone with experience setting this up, please chime in.
Thanks!
Thanks!
N9CHM on eHam raved abut using two of these antennas on the 6500. Perhaps you might contact him on QRZ.com to discuss how he set it up.
Jim, K6QE
Hi Jim.
I have much the same setup as you do, and connected the Pixel Loop to RX-B as you suggested. Doing that allows you to use the Diversity feature of the 6700, which is very slick indeed. I have not bothered to hook up the relay input on the Pixel Loop power box to disable the loop during transmit. The loop is about 350 feet away from the transmit antenna, and even running 1500 watts does not bother the loop. If you really think you need to enable that, just run a cable from TX2 to the Loop power box, assuming you are using TX1 to key your amp.
That's a great setup you have. Enjoy and Merry Christmas.
73, Army AE5P
Whoops, that was intended for Mike. Someday I'll learn to pay closer attention, maybe.
73, Army
Army, thanks! Just what the doctor ordered (pun intended)!
Merry Christmas to you as well (and Jim).
Mike N1MD0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
