rtty split
Larry Davis
Larry Davis Member ✭✭
i posted on this site about 6 months ago about rtty split yes you can split 10kc  not very fast not like psdr so when you trying to work ft5zm  or ft4ta and there on 10 meters 28080 and the split 30 up i don,t have a problem on ssb or cw hope the rtty split will be as easy as psdr
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited November 2017
    The logging program that I use allows the use of more than one RTTY decoder/encoder at the same time.  One decoder on the DX station/slice and a second decoder ( with TX ) on the split frequency slice..  Each decoder/slice uses a separate DAX channel.   Works quite well.
    Al, K0VM
  • on5po
    on5po Member ✭✭
    edited January 2017
    Hello,  I have the same problem, always not found of solution
    if there is a solution thank you to give it
    73,ON5PO, Janny
  • Tim - W4TME
    edited December 2016
    Al - what logging program are you using that has this capability?
  • Larry Davis
    edited November 2014
    i use n3jfp logging for rtty i use fldigi
  • on5po
    on5po Member ✭✭
    edited January 2017
    Hello,
    I use DM780 6.2.72.303 and DDutils 3.0.9.03
    Janny
  • Al K0VM
    Al K0VM Member ✭✭✭
    Tim,
      I am using Logger32 for my non-contest and run one copy of MMTTY and one copy of Two-Tone.. And with N1MM I have run three several copies of Two-tone
    Al, K0VM
  • Tim - W4TME
    Thanks for the info, Al.
  • James Kennedy-WU5E
    James Kennedy-WU5E Member ✭✭✭
    edited June 2020
    I got MMTTY working on split. too easy go to
    OPTIONS: Setup MMTTY : Sound card: I have two slices open slice one had DAX 1 for receive and DAX two had slice two for Transmit, side note I was watching Acts of Valor on the other screen and had to turn it off or there was a delay of 1 or 2 secs. IMPORTANT  open up the DAX control panel and make sure DAX 2 is TX ready.
    have fun on RTTY 73's de Jim
  • on5po
    on5po Member ✭✭
    edited January 2017
    hello,  who could help me how to open the second chanel of the DAX
    I only have dax chanel 1 open
    to be able to make the split in rtty of more than 10Khz
    I have win7,64 bits, flex 6300, and DM780
    so possible with photos
    thank you for advance
    on5po@hotmail.fr
    on5po, Janny
