rtty split
Larry Davis
i posted on this site about 6 months ago about rtty split yes you can split 10kc not very fast not like psdr so when you trying to work ft5zm or ft4ta and there on 10 meters 28080 and the split 30 up i don,t have a problem on ssb or cw hope the rtty split will be as easy as psdr
The logging program that I use allows the use of more than one RTTY decoder/encoder at the same time. One decoder on the DX station/slice and a second decoder ( with TX ) on the split frequency slice.. Each decoder/slice uses a separate DAX channel. Works quite well.
Al, K0VM
Hello, I have the same problem, always not found of solution
if there is a solution thank you to give it
73,ON5PO, Janny0 -
Al - what logging program are you using that has this capability?0
i use n3jfp logging for rtty i use fldigi
Hello,
I use DM780 6.2.72.303 and DDutils 3.0.9.03
Janny0 -
Tim,
I am using Logger32 for my non-contest and run one copy of MMTTY and one copy of Two-Tone.. And with N1MM I have run three several copies of Two-tone
Al, K0VM
Thanks for the info, Al.0
I got MMTTY working on split. too easy go to
OPTIONS: Setup MMTTY : Sound card: I have two slices open slice one had DAX 1 for receive and DAX two had slice two for Transmit, side note I was watching Acts of Valor on the other screen and had to turn it off or there was a delay of 1 or 2 secs. IMPORTANT open up the DAX control panel and make sure DAX 2 is TX ready.
have fun on RTTY 73's de Jim
hello, who could help me how to open the second chanel of the DAX
I only have dax chanel 1 open
to be able to make the split in rtty of more than 10Khz
I have win7,64 bits, flex 6300, and DM780
so possible with photos
thank you for advance
on5po@hotmail.fr
on5po, Janny
- 694 The Flea Market
