My 1500 no longer keying externally
Don
I really need help as I'm on a short vacation in western Panama (HP3) and before I could get my station in operation, I cannot seem to key my 1500 with an external key or keyer. Setup: PSDR ver. 2.7.2, Windows Vista on a Toshiba laptop. The 1500 works (puts out power) in Tune mode, or if I depress the MOX button. Not band dependent, using CWU mode. I do have VAC installed in preparation for PSK31, but VAC buttons not activated.
I believe I have all the setting correct, but this might be the cause as I haven't used my 1500 much before this trip. The rig did work fine (fine = external keying worked fine), but it is possible I may have changed something. Is there some setting that I am overlooking? When I close the external key, nothing happens. I can go through and give all my settings, but someone smarter than I am might just easily point out my error. Of course, time is of essence with this problem as I only have about 8-9 days left to operate from here. Thanks, Don HP3/AE5K
PS - forgot to mention I also have VSP installed, but of course not being used for CW, only PSK31.
I presume you have the key connected directly to the radio. Make sure you have the keyer configuration set correctly in the Setup form.
Also, does CWX work?
Hi Tim, Thanks for reply.
Yes, CWX works fine.
Yes, I have straight key (right now) connected directly to the key jack on the 1500 front panel.
As to settings, they appear to be OK to me, but I've written down most (except those that are default or cannot affect keying), but cannot see a way of attaching a file to this reply and cannot seem to paste them into this message.
Don HP3/AE5K
Try to drag and drop the file into the editor.0
The drag and drop did not work for me.
Here's the file that I typed up copying from the screens: ( X indicates box checked)
HP3/AE5K Flex 1500 - PowerSDR v. 2.7.2 2014 Nov 04
General->Hardware Config - n/a
General->Options:
X Spur reduction
X Disable split on band change
DIGU 1500
DIGL 1500
X Strict DB import compliance
Process priority: normal
X Snap click tune
USB Driver buffer: 2 out of 5 (conservative)
Keyboard:
X Enable shortcuts
X Quick QSY
General->Calibration - n/a
General->Filters (default)
General->RX2 - n/a
General->Navigation
Space navigator: X VFO control
Audio->Primary
Buffer size 2048
Audio->VAC1 - n/a
Audio->VAC2 - n/a
Display - n/a
DSP->Options (default)
DSP->Image reject (default)
DSP->Keyer
CW pitch freq 600 hz
Break in X enabled
Delay ms 300
Connections:
Primary: radio
Secondary: none
X Disable UI MOX changes
Options:
X Sidetone
X 2-wire cable
AGC/ALC - n/a
Transmit
Profiles: default
PA Settings - n/a
Appearance - n/a
Keyboard - default
CAT Control
Enable CAT
Port COM6
Baud 57600
Parity N
Data 8
Stop 1
PTTControl - port COM7
ID as PowerSDR
DIGL 2125
DIGU 2125
Tests - n/a
NOTE: CW Memories and Keyboard seem to work fine and will key the transmitter.
Hope this might help. If you deem any of the "n/a" entries are needed, just hollar.
Don HP3/AE5K0 -
The relevant settings are in DSP->Keyer Your list does not include all of them.
For paddles (3 wire) the following have the be checked or enabled
Iambic
Sidetone
Mode B
Break In enabled with a delay value set for your fist speed and if you want QSK.
For a straight key (2 wire) connected to the back, you must un-check Iambic (turn off the internal keyer).
If you are using the com port to connect the keyer, the Secondary Connection should be the com port the keyer is connected to.
Hi Tim,
In my previous list, in the interest of brevity, I did not mention items if they were NOT checked. Therefore, using a straight key plugged into the FRONT (no back jack as you said), Iambic is not checked. Here is the relative portion of my previous list:
DSP->Keyer
Break in X enabled
Delay ms 300
Connections:
Primary: radio
Secondary: none
Options:
X Sidetone
X 2-wire cable
AGC/ALC - n/a
Iambic is also not checked on the screen display either.
Don - HP3/AE5K
I am not sure that is going on. I would so a database reset and if that doesn't resolve the problem, open up a HelpDesk support ticket, This could be a hardware issue.0
TNX for the rapid reply, appreciated. Will try that shortly and if reset works will let you know, else will start ticket. As I said originally, the keying used to work but I thought I may have changed something in the settings that killed it.
Tim, tried the database reset, still no luck. Since the keyboard is working, I can still operate CW, but really prefer my keyer. I will open up a HelpDesk support ticket, but only after I get home in more than a week.
Don HP3/AE5K
OK Don. We'll get to the bottom of it when you get back. Have fun on your vacation.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
