Monitor Mode when using digital modes?
Gary Franklin
I recently acquired a 6300. Upgraded from a 5000. I for some reason am not able to monitor (with the MON button) digital modes. Not available?
When the DAX button is enabled, the monitor function does not work. I'm not sure if this is by design . In any case, that's the long and short of it. Be sure to turn DAX off when wanting to monitor your own audio on voice modes. That has caught me a number of times.0
It also occurrs to me that when using the mon mode and DAX enabled, it would create an extreme feedback loop, if you happen to be using both the Dax line through the computer speakers AND the audio feed directly from the Flex's output to the same speakers at the same time.... ?? Hence the reasoning for disabling the DAX on Mon. I have an expected echo of sorts when using Dax and Flex output to the same speakers under "normal" operating conditions so I tend to either stop the Dax channel or Mute the speaker output directly from the flex, depending on the "mood" or mode.0
The way to do it is to set the Windows mixer recording properties for the DAX TX1 to "Listen to the device".
It's a bit of a faff really as the DAX isn't fully handled in the window mixer, or SSDR either. I've suggested improvement here:
https://community.flexradio.com/flexradio/topics/dax-windows-mixer-integration0 -
If there is no transducer (mic) to pickup the audio and feed it back into the radio, there is no chance of feedback in digital modes.0
I have the problem that when i install the software the audio through my monitor speakers is disabled.How do i get the audio enabled ?Thanks for any help.0
Dolan - the ability to monitor audio from a DAX channel is a feature that is not supported yet in SmartSDR.0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
