SmartSDR v3.3.32 and the SmartSDR v3.3.32 Release Notes | SmartSDR v2.7.6 and the SmartSDR v2.7.6 Release Notes
Power Genius XL Utility v3.6.24 and the Power Genius XL Release Notes v3.6.24
Tuner Genius XL Utility v1.1.8 and the Tuner Genius XL Release Notes v1.1.8
Deleting ssdr
Tony Hateley
I have just built myself a new desktop computer to run my new flex on,at the moment I run it on my laptop but it is not ideal,do I just delete it of my laptop and then just re download from flex and install one new desktop.thank you
You do not delete SmartSDR, you uninstall it via the Uninstaller that is located in the All Programs menu for FlexRadio SystemsSmartSDR v or from the Windows Control Panel. When you run the uninstaller, make sure you respond properly to the question about removing the DAX drivers. After the uninstaller finishes, you have to manually remove FlexVSP, which is the virtual serial port driver. Then reboot your PC and SmartSDR will be completely uninstalled.0
Tony
Don't forget Export your profiles onto a flash drive then import them into the new computer.
Save you time.
Ian
- 18.5K All Categories
- 132 Community Topics
- 2K New Ideas
- 279 The Flea Market
- 6.2K Software
- 5.4K SmartSDR for Windows
- 93 SmartSDR for Maestro and M models
- 211 SmartSDR for Mac
- 188 SmartSDR for iOS
- 180 SmartSDR CAT
- 115 DAX
- 321 SmartSDR API
- 7.8K Radios and Accessories
- 6.4K FLEX-6000 Signature Series
- 631 Maestro
- 29 FlexControl
- 777 FLEX Series (Legacy) Radios
- 409 Genius Products
- 241 Power Genius XL Amplifier
- 145 Tuner Genius XL
- 23 Antenna Genius
- 119 Shack Infrastructure
- 75 Networking
- 204 Remote Operation (SmartLink)
- 91 Contesting
- 306 Peripherals & Station Integration
- 87 Amateur Radio Interests
- 581 Third-Party Software
