Deleting ssdr
Tony Hateley
I have just built myself a new desktop computer to run my new flex on,at the moment I run it on my laptop but it is not ideal,do I just delete it of my laptop and then just re download from flex and install one new desktop.thank you
You do not delete SmartSDR, you uninstall it via the Uninstaller that is located in the All Programs menu for FlexRadio SystemsSmartSDR v or from the Windows Control Panel. When you run the uninstaller, make sure you respond properly to the question about removing the DAX drivers. After the uninstaller finishes, you have to manually remove FlexVSP, which is the virtual serial port driver. Then reboot your PC and SmartSDR will be completely uninstalled.0
Tony
Don't forget Export your profiles onto a flash drive then import them into the new computer.
Save you time.
Ian
- 684 The Flea Market
