Apple Thunderbolt to Firewire 800 adapter works well with PowerSDR
I have been concerned that the lack of FireWire ports on new computers was going to be a problem for Flex 3K & 5K owners that wanted to upgrade their computers. I am running PowerSDR on my Mac mini using Bootcamp and Windows 8.1 but this is the last Mac computer to support FireWire directly.
Apple has released a $29 Thunderbolt to FireWire adapter that works well with either Windows or OS X so I purchased one today. I plugged it in, removed my FireWire 800 to 400 cable from the built in port and re-connected it to the $29 adapter. PowerSDR 2.7.2 came up running just fine wit no indications of any issues.
73 - Mike - K9JRI
I can concur with this, it worked for me when I tested it on an Asus G750vx laptop.
730 -
As my old SYBA TI Firewire Expresscard dont work on my new Thinkpad P71, can I conect my Flex 3000 firewire cable to USB C notebook conector using the Apple adaptor?0
3 weeks ago
Tim - W4TME, Customer Experience
There isn't an alternative solution to using the FLEX-5000 and FLEX-3000 with a non-native Firewire interface. It will just not work if the 1394 bus is being emulated by a different physical interface. It will also not work if the FIrewire interface is not 100% IEEE 1394 compliant too. The only thing I have heard might work is a Thunderbolt interface with the Firewire connector.0 -
I tested my 5000A with an Apple Thunderbold->1394 adapter and it came up and worked for a few minutes. I was using the thunderbolt port from an ASUS ROG 17" laptop. I did not do extensive tests but it came up and worked for everything I did for a while.
YMMV0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
