V1.3.8 is not initializing AM mode in RX at start-up....
k0eoo
k0eoo Member ✭✭✭
edited March 2017 in SmartSDR for Windows
When I start-up my 6500 on my PC running W7 and V1.3.8 I noticed the S-meter does not read correctly if the Slice I'm on is in AM mode....  It reads very low...  To correct all I do is select some other mode on that slice and re-select AM and all is well...  I've been able to repeat this behavior many times...
This is just a heads-up for the FRS team...  This issue is not causing me any problem, just thought the team would like to know.  Regards, Dennis, k0eoo
  • Tim - W4TME
    edited March 2017
    Are you using SAM or AM?  Is there a difference if you use either of these modes?
  • k0eoo
    k0eoo Member ✭✭✭
    edited March 2017
    Hi Tim,
    I was in the AM mode each time this happened....  I didn't understand your second question.
    Dennis, k0eoo
  • Tim - W4TME
    edited December 2016
    Since you are using AM, does the same behavior happen with SAM?
  • k0eoo
    k0eoo Member ✭✭✭
    edited March 2017
    The answer is no.  I usually only use the SAM mode during QSB conditions so I have never had the occasion to start-up my 6500 with it in SAM mode....
