100% duty cycle modes
Hi Al, I have got DDUtil up and running. I needed to use it as Ham Radio Deluxe does not play nice with SSDR so I read. Connecting to the radio was certainly much more reliable with the DDUtil server up and running. HRD a tad too flaky and too expensive for my needs but I do like the way things are laid out. I will have it running to monitor the PA temp - thanks for the suggestion.
I cheat! Actually I should have qualified my full power comments in RTTY. I have a SteppIR MonstIR. It's virtually SWR 1:1 everywhere So I likely can run high power for much longer than most people as most of my power goes out the antennaz0
That is not cheating .' its utilizing your environment '
Similar here just separate beams for bands used and amps with low IMD .
Can run "legal out all day long" in any mode .
Flex is fantastic.... DAX inter-phase is hard to beat using just about everything out there.
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
