CW Pitch Not in Profiles?
Jim KJ3P
Member ✭✭✭
I note that the CW pitch does not seem to be saved with either the Global or Transmit profiles. This would certainly be important to us CW folks.
If I’ve missed something, please enlighten me!
--Jim KJ3P
Which rig are you running? CW pitch is being saved correctly on the Transmit Profile on my 6500. But be sure you are giving it a name and correctly saving it to that name and correctly recalling it.0
Rig: 6300
Tried saving and recalling under a couple different names, both Global and TX, but profile is always called back with a 100 Pitch (I had it set to 750 during all saves).
I now recall that a bug has been reported that does that if you are using CWL instead of CWH. When you said it defaults back to 100 Hz it reminded me of it. I have not used the other sideband setting for CW, thus no problem.0
That did it! I've changed back to CWH, since the Pitch is more important to me for Profile recall. Glad to hear that this bug has been reported. Thanks a bunch.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
