CW Pitch Not in Profiles?
Jim  KJ3P
Jim KJ3P Member ✭✭✭
I note that the CW pitch does not seem to be saved with either the Global or Transmit profiles. This would certainly be important to us CW folks.
If I’ve missed something, please enlighten me!
   --Jim KJ3P
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    Which rig are you running? CW pitch is being saved correctly on the Transmit Profile on my 6500. But be sure you are giving it a name and correctly saving it to that name and correctly recalling it.
  • Jim  KJ3P
    Jim KJ3P Member ✭✭✭
    edited April 2020
    Rig:  6300
    Tried saving and recalling under a couple different names, both Global and TX, but profile is always called back with a 100 Pitch (I had it set to 750 during all saves).
  • Ken - NM9P
    I now recall that a bug has been reported that does that if you are using CWL instead of CWH.  When you said it defaults back to 100 Hz it reminded me of it.  I have not used the other sideband setting for CW, thus no problem.
  • Jim  KJ3P
    Jim KJ3P Member ✭✭✭
    edited April 2020
    That did it! I've changed back to CWH, since the Pitch is more important to me for Profile recall. Glad to hear that this bug has been reported. Thanks a bunch.
