Saving Panadaptor profiles
G4BIM
G4BIM Member
edited March 2017 in SmartSDR for Windows
Ver 1.3
Don't use the waterfalls, after dragging them all to the bottom of the display for each band slice, I find that this is not saved in the Global Profiles, so each time you re load a Global profile you have to manually suppress the waterfalls again in each slice.
Can you fix this irritating issue please?
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited March 2017
    This sounds like another of the the "GUI configurations"  Tim referred to in this post:
    https://community.flexradio.com/flexradio/topics/v1_3_profiles_and_persistence_of_the_transmit_panel
    ***** excerpt below *****
    Tim,
    Thanks, can you provide a list of other items like the transmit panel persistence that are considered GUI specific, not already persisted, and not part of the profiles enhancement?    It would be helpful to include the status for each one.  That way if you note something that is not planned or being considered, we can submit an idea if there is adequate interest.  I can't think of many other things that aren't already persisted so maybe its a short list.  On the other hand, I'm CW only and only use a limited number of the features.
    Something simple like this would be good.
    Item and status
    1 - Transmit panel order - on list for possible inclusion in a future release
    2 - Equalizer to display last setting (i.e. RX or TX) - status ???
    3 - etc
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
  • philip.theis
    philip.theis Member ✭✭
    edited December 2014
    It's coming in the future:  [Note: Graphical User Interface layout settings are not stored in v1.3 but may be included in a future version.]
    From the User Manual
  • Tim - W4TME
    edited March 2017
    "This sounds like another of the the "GUI configurations"  Tim referred to in this post:
    https://community.flexradio.com/flexradio/topics/v1_3_profiles_and_persistence_of_the_transmit_panel"
    Is is a GUI configuration that is not included in the Global (radio) Profiles.
  • G4BIM
    G4BIM Member
    edited January 2015
    Would it be easier to have a global option to suppress waterfalls on all slices if the user does not require them?
