Saving Panadaptor profiles
G4BIM
Ver 1.3
Don't use the waterfalls, after dragging them all to the bottom of the display for each band slice, I find that this is not saved in the Global Profiles, so each time you re load a Global profile you have to manually suppress the waterfalls again in each slice.
Can you fix this irritating issue please?
This sounds like another of the the "GUI configurations" Tim referred to in this post:
https://community.flexradio.com/flexradio/topics/v1_3_profiles_and_persistence_of_the_transmit_panel
***** excerpt below *****
Tim,
Thanks, can you provide a list of other items like the transmit panel persistence that are considered GUI specific, not already persisted, and not part of the profiles enhancement? It would be helpful to include the status for each one. That way if you note something that is not planned or being considered, we can submit an idea if there is adequate interest. I can't think of many other things that aren't already persisted so maybe its a short list. On the other hand, I'm CW only and only use a limited number of the features.
Something simple like this would be good.
Item and status
1 - Transmit panel order - on list for possible inclusion in a future release
2 - Equalizer to display last setting (i.e. RX or TX) - status ???
3 - etc
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
.1 -
It's coming in the future: [Note: Graphical User Interface layout settings are not stored in v1.3 but may be included in a future version.]
From the User Manual0 -
"This sounds like another of the the "GUI configurations" Tim referred to in this post:
https://community.flexradio.com/flexradio/topics/v1_3_profiles_and_persistence_of_the_transmit_panel"
Is is a GUI configuration that is not included in the Global (radio) Profiles.
Would it be easier to have a global option to suppress waterfalls on all slices if the user does not require them?0
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
