Do I need an adapter between computer headphone and mic input on the flex 6300?
Oris Gremillion AB5FA
Member ✭
Mic adapter for flex 6300
well ::::
audio out in rear of flex .You will need a set of speakers that have amplifier in them. (Computer style Bose M-audio Etc)
Mike connector input You may need a pre amp depending on your mike choice. (Then again you might not)
If you dont have the speakers Plug in a set of headsets (front marked Phones) you may never want speakers???
If you get the headsets with the boom mike . You might never go for a mike????
Loads of options .
Yes0
If what your asking is ... If you are wanting to use a headset mic combination the answer is yes... I use a KOSS SB-45(less than $30.00 on Amazon) headset mic combo on my 6300 at times.... when I do I use
http://members.bellatlantic.net/~vze3rys4/adapter/ it works great..... plug and play... or get this from flex
http://cart.flexradio.com/ProSet-Headset-Cable-for-8-pin-Foster-connector_p_25.html either one will work...
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
