Do I need an adapter between computer headphone and mic input on the flex 6300?
Oris Gremillion  AB5FA
edited November 2015 in FLEX-6000 Signature Series
Mic adapter for flex 6300
  • np2g
    np2g Member ✭✭
    well ::::
    audio out in rear of flex .You will  need a set of speakers that have amplifier in them. (Computer style  Bose M-audio Etc)
    Mike connector input You may need a pre amp depending on your mike choice. (Then again you might not)
    If you dont have the speakers Plug in a set of headsets (front marked Phones)  you may never want speakers???
    If you get the headsets with the boom mike . You might never go for a mike????
    Loads of options .
  • Steve N4LQ
    Steve N4LQ Member ✭✭
    edited September 2015
    Yes
  • John n0snx
    John n0snx Member
    edited April 2015
    If what your asking is ... If you are wanting to use a headset mic combination the answer is yes... I use a KOSS SB-45(less than $30.00 on Amazon)  headset mic combo on my 6300 at times.... when I do I use
    http://members.bellatlantic.net/~vze3rys4/adapter/  it works great..... plug and play... or get this from flex
    http://cart.flexradio.com/ProSet-Headset-Cable-for-8-pin-Foster-connector_p_25.html    either one will work...
