Audio drops on 12 meters
Burch Akin
Just upgraded to SmartSDR 1.2.17 and when you drag the panadapter on 12 meters (not the slice), the audio drops out and the panadapter gets distorted. It only seems to do this on 12 meters. I'm not sure if it has been doing this before the update since I haven't been on 12 meters since I got the 6300. I worked a few stations on 12 meters so it it functional but it really strange when you change the panadapter frequency. Anyone else have this issue?
Burch
K4QXX
Burch
K4QXX
A 6300 here as well.
This occurs for me on 15, 17, and 12...however 12 meters is indeed the worse. I didn't notice it on the radio until after installing SmartSDR 1.2.17.
As you drag the panadapter to a portion of the band immediately off the screen (to the right or left of what is being displayed) an audio drop out occurs. 20 Meters and 10 Meters (on either side of these bands) scroll horizontally seamlessly...both audio and video are smooth.
Its not just you Burch.0 -
Same here Burch. Sounds choppy when you drag it. I didn't try it with the old software however so I don't know if this is a new thing or not.
Steve N4LQ0 -
Ditto. Choppy audio when dragging the panadapter with version 1.2.17. Worst on 12m, some on 17m. 1.2.1 did not do this.
I've entered this in our issue tracking system as issue #352. We'll investigate and report back.1
This problem has been found and fixed and will be available in the next release.4
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
