Issue with my 6500 on 20M
Keith Pawley
I am having a problem with my 6500 on 20M (software V1.2.1) I use the ATU to tune the radio which is fine the receive is normal at this time but as soon as I key the mike then De key the mike I have interference at peaks right across the band I have downgraded to V1.0.0 software and the issue still remains.
Please see picture after de keying the mike back on receive.
Any ideas guys would be greatly appreciated.
Do you get the same thing on a dummy load / different antenna?? Only on 20m ?
Does toggling ANT1>ANT2>ANT1 change anything ??
Al, K0VM
Hello Keith, I don't know if this is the problem but I notice you have the mic gain up all the way and you have the graphic EQ set all the way up from 1K and above. Maybe for this test switch off the EQ until this issue is resolved.
Do you have the +20dB preamp turned on in the SETTINGS>RADIO>PHONE tab? Maybe if you turned on the +20B preamp you could turn down the mic gain and for starters turn down the processor to NOR mode. See if any of that helps....
Dennis, k0eoo
Hi thanks for the quick replys I have the same fault with a different antenna also with mic gain down
and the preamp is off and it is only 20M I have the issue.
M0PAW0 -
Also same fault with antenna connected to no 2 Ariel connector on the back of the flex.
Keith,
It would seem to me that it is unique enough that it could be a hardware problem and that Flex helpdesk would be in-order.
Al, K0VM
My thoughts exactly I will get in touch with them today.0
Thanks all M0PAW Keith Pawley.0
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 123 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 698 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
