is it normal to have horizontal lines in the waterfall every time I tx
jim
It is if you don't have the waterfall on while TXing option selected.0
Setting is here....
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
al , my Show TX in Waterfall: is/was set to DISABLED
I must have something else set wrong
still looking
Jim,
Here is what I see in both states:
Regards, Al / NN4ZZ
**** DISABLED - lines when transmitting ***********
************ ENABLED signal when transmitting *************
OK here's the deal: we polled our Alpha team about the waterfall when they first began testing it. There were some that never wanted to see their transmit signal in the waterfall and others who felt that it had some diagnostic value. I'm in the latter camp for what it's worth. So we created a switch to let you choose which you prefer. The guys that didn't want to see transmit wanted some demarcation of when they were in transmit so they could clearly see what happened before and after transmit. So when the switch is disabled, we draw a white-black-white line (a double line) to show when transmit occurred.
When the switch is enabled, we reduce the power spectrum in the in waterfall (since you are so much louder than what you're listening to). The results in a black background with only your signal visible while you transmit.2 -
Good decision, give options and clearly marking the transmit line.....works as designed.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com.0 -
ok AL,
now i understand thank you very much
and a picture is worth 1000 words .
agn thanks
jim wb5aaa0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
