HRD 6.2 RC2 Logbook with DDUtil 3.0.6 HRD App server and SMartSDR issues
Using SmartSDR 1.2.1, DDUtil 3.0.6 and HRD 6.2 RC2.
Anyone else using this combo with DDUtil's HRD App server checked in place of HRD's main program when using HRD logbook with success? I noticed from HRD 6.1.4 to HRD 6.2 RC2 that the radio name in HRD Logbook radio pane (when connected to HRD main program and not DDUtil HRD TCP server) has changed from PowerSDR to PowerSDR SmartSDR. I think that change in HRD 6.2 RC2 is causing issues with DDUtil.
The problem is when I run DDUtil's HRD App server checked and then launch HRD Logbook 6.2 RC2 the radio pane does not show any buttons and mode changes from clicking on cluster spots does not work.
I want to get feedback from any users successfully using the HRD Logbook 6.2 RC2 with DDUtil's HRD App serer. I do a lot of software beta testing on this PC and before I format and reinstall I want to see if this is a widespread issue. I suspect HRD changed the name of the radio that gets echo'ed back to HRD logbook from the main program with the upcoming 6.2 and that might be causing grief with DDUtil. Anyone who has used DDUtil in place of the HRD main program to interface the logbook and DM780 knows the software is MUCH more responsive than having HRD main program talk to SmartSDR Cat.
Thanks in advance.
Dave
wo2x
Yep, I am running the same combo with the same issues. It works great with the KX3 but not the 6500
Dan KM6CQ0 -
I just substituted MiniDeluxe in place of DDUtil. The problem is HRD changed the name that HRD logbook 6.2 RC2 is expecting to PowerSDR SmartSDR. Since both miniDeluxe and DDUtil echo PowerSDR it fails as unknown radio and the buttons in the radio pane of HRD Logbook are missing.
The source code of MiniDeluxe is available for download so I am going to figure out how to change it and recompile with the correct name.
Stay tuned....
Dave, wo2x
Okay thanks Dave. I don't know much about coding but I can sure cut and paste. I will be awaiting your instructions.
Dan0 -
I wait with interest too. A few days ago I asked a similar question, where I am thinking of upgrading from the free version of HRD (5) to the current version 6.2 RC2. In the meantime I've moved away from using DDUTil 3 and used MiniDeluxe, and this seems to work well with the logbook and DM780. If the above problems can be overcome I'll be more tempted to upgrade.
Jeff - G4IUA0 -
Hi All,
Here's a status update. Seems the new 6.2 HRD suite changed the radio name that HRD main program echoes back to HRD Logbook and DM780. HRD Logbook sends Get Radio command on startup and is expecting 3:PowerSDR SmartSDR as the reply, not 11:PowerSDR as older versions. DM780 sends Get Radios (plural) and expects the same reply.
MiniDeluxe - Dave, W0DHB, has modified the source code and has sent me a beta version to test. All is working very nicely. Once the release version is out it will be posted on www://vhfwiki.com/minideluxe
DDUtil - I've been working with Steve, K5FR (author of DDUtil) to incorporate the same changes. He has incorporated the logbook changes and that is working perfectly. I am sending Steve the changes for DM780 later today.
The advantage of running either MiniDeluxe or DDUtil in place of the main HRD program is much faster responsiveness from clicking on cluster spots for mode/frequency QSY changes. Also frequency changes from clicking on waterfall in DM780 are much faster.
Dave, wo2x
Thanks for the update Dave - looking forward to the new release versions of DDUtil and MiniDeluxe to streamline things.
Jeff - G4IUA0 -
It should be noted that the Minideluxe issue also happens with PowerSDR as well as SmartSDR. if there are one or two others who would like to check out Minideluxe changes, Please let me know and I will make it available.
Dave W0DHB1 -
Thanks for the helpDave! 73 Dave, wo2x0
Thank you Dave.
Dan KM6CQ0 -
Until Dave K1FSY gets Minideluxe download site at VHFWiki updated, you can find a copy here
https://www.dropbox.com/s/qxa52ml2eh6ham4/MinideluxeHRD6_2.zip
Dave W0DHB
I've finally had chance to look at some of reported Minideluxe and/or DDutil HRD pulldown issues with both PowerSDR and SmartSDR.
For PowerSDR only the Mode pulldown has issue (SmartSDR has same problem)
- When selecting mode, mode changes correctly in PSDR and SSDR, but the label on the button is not correct. I'm looking into this.
SmartSDR issues
Band Pulldown does not work at all, it's using a CAT command that's not implemented yet. (Set/Read Band). Workaround will be to use Set freq .
AGC Pulldown does not work because CAT command is not implemented in SSDR. Not clear if PSDR command will map to the SSDR AGC UI
Display Pulldown - same as AGC pulldown
Filter Pulldowns - Currently SSDR Filters are not as definable as PSDR, immediate solution will be to "Hardwire" filters when using SmartSDR.
Note that HRD itself has many of the issues listed above with SSDR.
I'm pushing the HRD folks to a separate PowerSDR and SmartSDR into two Radio types.
With the current situation between HRD and DDUTIL, going forward it would be best if HRD gave us the option to run DM780 and Logbook as a stand alone app. I don't see HRD changing anything to accommodate DDUTIL in the future.
73, Dan0 -
The current versions of HRD (6.2.9.254) and DDUtil (3.1.0.17) work fine with SSDR, at least as concerns HRDLog, DM780, and HRD Rotator. ( I never use the HRD main program) The problems mentioned in the OP were artifacts of much older versions of both programs.
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
