ACC Port/Pactor and Version 1.2.1
Travis Best
Seems to be a issue with the ACC port since upgrading to version 1.2.1 The when using the ACC port the BAL line audio is no longer muted and the levels just done seem right with the ACC.
Make sure that you have selected the ACC in the input drop down box and not just click on the ACC button when will enable dual audio inputs based on what is selected in the drop down box.0
Yes that is the way I have it set and using my existing setup that was working fine in the previous version the audio coming from my Pactor modem no longer drives my radio and as soon as I talk into the MIC that is connected to the BAL line I see drive while the pastor has the transmitter keyed0
Thanks for the feedback, Travis. I have entered this report into our bug tracker for further investigation. Thanks.0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 331 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 777 Maestro
- 42 FlexControl
- 730 Genius Products
- 253 Tuner Genius XL
- 85 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
