ACC Port/Pactor and Version 1.2.1
Travis Best
Seems to be a issue with the ACC port since upgrading to version 1.2.1 The when using the ACC port the BAL line audio is no longer muted and the levels just done seem right with the ACC.
Make sure that you have selected the ACC in the input drop down box and not just click on the ACC button when will enable dual audio inputs based on what is selected in the drop down box.0
Yes that is the way I have it set and using my existing setup that was working fine in the previous version the audio coming from my Pactor modem no longer drives my radio and as soon as I talk into the MIC that is connected to the BAL line I see drive while the pastor has the transmitter keyed0
Thanks for the feedback, Travis. I have entered this report into our bug tracker for further investigation. Thanks.0
- 391 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 309 FLEX-8000 Signature Series
- 979 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
