ACC Port/Pactor and Version 1.2.1
Travis Best
Travis Best Member ✭✭
edited March 2017 in SmartSDR for Windows
Seems to be a issue with the ACC port since upgrading to version 1.2.1  The when using the ACC port the BAL line audio is no longer muted and the levels just done seem right with the ACC.
    edited March 2017
    Make sure that you have selected the ACC in the input drop down box and not just click on the ACC button when will enable dual audio inputs based on what is selected in the drop down box.
  • Travis Best
    edited May 2014
    Yes that is the way I have it set and using my existing setup that was working fine in the previous version the audio coming from my Pactor modem no longer drives my radio and as soon as I talk into the MIC that is connected to the BAL line I see drive while the pastor has the transmitter keyed
    edited March 2017
    Thanks for the feedback, Travis.  I have entered this report into our bug tracker for further investigation.  Thanks.
