SAM Mode Causes SDRcat to Crash
Hi All,
I am using a Flex6500 running version 1.2.1 and SDRcat V1.2.3.0.
Windows 7 Pro operating system.
Every time I select SAM mode SDRcat crashes.
Initially I thought it was just when I changed bands and the SAM mode was selected but I have noticed that it is every time I select SAM mode.
This causes the SDRcat to crash, I have recreated on all bands and used all modes, then as soon as I select SAM it crashes.
I have rebooted the computer and radio and reset the radio back to default settings but it is exactly the same, SAM = SDRcat crash.
Not a major problem, as soon as I start SDRcat again it works fine as long as I am not in SAM mode.
Anybody else had this problem.
Peter
Yes, but I've only seen it crash when using my Dell Venue 8 Pro running under Win 8.1. No CAT crashes in SAM when using my main PC running under Win 7 Pro. On the tablet, I can get CAT back after selecting SAM but any subsequent mode change causes CAT to crash again.0
Peter. SmartCAT v1.2.8 is the latest version and was released with SmartSDR v1.2.1. You will need to follow the instructions in the Release Notes to update your SmartCAT driver. That should fix you up!
73, Greg - K5GJ
FlexRadio0 -
Greg, that seems to have fixed it here. Tnx! Paul, W9AC0
Ok Greg thanks for that, I thought it had updated when I installed the new software.
I will update it immediately.
Peter
Fixed it Greg thanks again0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
