SAM Mode Causes SDRcat to Crash
Peter
Peter Member ✭✭
edited January 2020 in SmartSDR for Windows
Hi All,
I am using a Flex6500 running version 1.2.1 and SDRcat V1.2.3.0.
Windows 7 Pro operating system.
Every time I select SAM mode SDRcat crashes.
Initially I thought it was just when I changed bands and the SAM mode was selected but I have noticed that it is every time I select SAM mode.
This causes the SDRcat to crash, I have recreated on all bands and used all modes, then as soon as I select SAM it crashes.
I have rebooted the computer and radio and reset the radio back to default settings but it is exactly the same, SAM = SDRcat crash.
Not a major problem, as soon as I start SDRcat again it works fine as long as I am not in SAM mode.
Anybody else had this problem.
Peter
  • Paul Christensen, W9AC
    Paul Christensen, W9AC Member ✭✭
    edited February 2017
    Yes, but I've only seen it crash when using my Dell Venue 8 Pro running under Win 8.1. No CAT crashes in SAM when using my main PC running under Win 7 Pro. On the tablet, I can get CAT back after selecting SAM but any subsequent mode change causes CAT to crash again.
  • Greg - K5GJ
    Greg - K5GJ Member ✭✭
    edited January 2020
    Peter.  SmartCAT v1.2.8 is the latest version and was released with SmartSDR v1.2.1.  You will need to follow the instructions in the Release Notes to update your SmartCAT driver.  That should fix you up!
    73, Greg - K5GJ
    FlexRadio
    edited November 2016
    Greg, that seems to have fixed it here. Tnx! Paul, W9AC
  • Peter
    Peter Member ✭✭
    edited May 2014
    Ok Greg thanks for that, I thought it had updated when I installed the new software.
    I will update it immediately.
    Peter
  • Peter Moran
    Peter Moran Member
    edited May 2014
    Fixed it Greg thanks again
