I am having trouble transmitting RTTY via MMTTY
Bill AA7XT
I am using the latest version of SmartSDR and MMTTY v1.66G. I am in DIGL mode and have selected DAX channel 1 in Slice RX A and selected the DAX button in the P/CW window. I am able to decode RTTY signals in MMTTY OK but cannot TX. I suppose I need to get the PTT signal from SmartSDR to MMTTY but cannot figure out how to do this. Have Googled to no avail. Help!
Have you activated channel 1 in the DAX control panel and set it forTX ? Tim NZ8J0
First you must be running current version of SmartSDR Cat
Then in MMTTY Options
Setup mmtty
TX Tab
PTT & FSK PORT = NONE
RIG COMMAND TAB
Set Port to either
a Port that you setup in SmartSDR Cat as PTT RTS/DTR
OR use the Port named in SmartSDR Cat on the Main Tab
"Connect 3rd Party Programs to Port"
This should get PTT and TX to work. Hope this helps some.
Ken W9IE0 -
Yes0
SmartSDR CAT will not let me add a new port. nothing happens when I click "add a port"0
Yes, I am running current version of SmartSDR and SmartSDR CAT. I have 8 physical serial ports on my Win 7 Pro PC, I wounder if that is causing problems? I am able to connect my logging program (DX Lab) to virtual serial port 9 via SmartSDR CAT.0
Delete your Smart CAT software and re-install it.Then re-enter your com/ports. Make sure you see SmartSDR IP address (192.1...etc...) when you click the CAT software.
That should show on the lower right corner, above the taskbar clock.
I have changed this post to a problem topic and converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
