How to wait for a slice to be ready?
Drax
What is the proper way to wait for a slice to be ready to accept property modifications after I've created it?
Waiting for the slice created event doesn't seem to be enough. I tried putting a set slice.freq command in the event, but it doesn't work. But if I wait some time and then change the slice's frequency it will do it.
Obviously there is some other event, besides slice created, a or property I have to monitor before I start making demands of the slice. What is it?
Drax,Here is a snippet of how I do that in CAT:
public void SliceAdded(Slice slc) { switch (slc.Index) { case 0: if (slice0 == null) { slice0 = slc; slice0.PropertyChanged += new PropertyChangedEventHandler(slice0_PropertyChanged); slice0.SMeterDataReady += new Slice.SMeterDataReadyEventHandler(slice0_SMeterDataReady); //initialize the current_receive_slice if (current_receive_slice == null) { current_receive_slice = slice0; Set("Freq0", slice0.Freq.ToString()); } string split_status = "00"; if (slice0 != null && slice1 == null && slice0.Transmit) { split_status = "00"; this.CurrentTransmitSlice = 0; }The SliceAdded(Slice slc) method is called from the radio slice_added event handler.
Hope this helps,
Bob
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
