No persistence on 160m band!
W0QKL
Ver 1.0.24 when I go to the 160m band I have to click on Add Slice Reciever to get slice A then if you move to any other band then back to the 160m band the slice will not return until you do another Add Slice Reciever, Looks like the persistence does not work for the 160m band. ANY ONE ELSE HAVE THIS PROBLEM? I see some on had a like problem on 12 m but in my case even after you add the slice once you move off the band and return you have to click +RX again.
I posted this problem last week. Here's my temporary fix: 1) Go to 160m and open up a new panadapter (not slice) for 160. This is opened on the lower left corner of the screen. You now have two pan displays with the new pan now showing Slice A; 2) Now Exit out of the prior pan that shows no slice; 3) Move the slice around in the new pan just a bit so it saves; 4) Go to another band and then back to 160m. You should now have 160m persistence. It's beta software and I'm confident Flex will address this. Paul, W9AC0
Thanks Paul we will try this.0
This issue has been added to our bug tracker for further investigation. Thanks for the report.0
- 249 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
