No persistence on 160m band!
W0QKL
Ver 1.0.24 when I go to the 160m band I have to click on Add Slice Reciever to get slice A then if you move to any other band then back to the 160m band the slice will not return until you do another Add Slice Reciever, Looks like the persistence does not work for the 160m band. ANY ONE ELSE HAVE THIS PROBLEM? I see some on had a like problem on 12 m but in my case even after you add the slice once you move off the band and return you have to click +RX again.
I posted this problem last week. Here's my temporary fix: 1) Go to 160m and open up a new panadapter (not slice) for 160. This is opened on the lower left corner of the screen. You now have two pan displays with the new pan now showing Slice A; 2) Now Exit out of the prior pan that shows no slice; 3) Move the slice around in the new pan just a bit so it saves; 4) Go to another band and then back to 160m. You should now have 160m persistence. It's beta software and I'm confident Flex will address this. Paul, W9AC0
Thanks Paul we will try this.0
This issue has been added to our bug tracker for further investigation. Thanks for the report.0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
