Digital Mode Headache
W5UN_Dave
Using fldigi and DAX.....sometimes it works, sometimes it doesn't. It worked in the beginning, Now, it mostly doesn't work. I have tried rebooting everything, to no avail. I install, uninstall, and reinstall DAX RX/TX 1. Nothing seems to matter. Either I am doing something incredibly dumb, or there is some kind of problem. Am I the only one experiencing this? (Yes, I have checked fldigi audio and radio settings, for those who are about to ask)
Dave, When you say doesn't work, are not seeing the frequency displayed, no seeing anything in the waterfall of FLDigi, or just fails to come up and what kind of error when this happens?0
Dave, There is a "SmartSDR.xml" file on the FlDigi site. Written by Tim, I think. http://www.w1hkj.com/xmlarchives.html I have no idea what the difference might be. Ned, K1NJ0
If you've re-installed DAX, there's a good chance there are a BUNCH of ghost audio devices still in the Device Manager.They seem to remain after an uninstall, even after rebooting. Try uninstalling DAX again, then rebooting, then going to Device Manager (Windows Control Panel). Ensure you select View -? Show Hidden Devices. Delete every last DAX device. Reboot. Reinstall DAX. You may need to re-configure FLDigi to get the new devices to "stick." Good luck!1
How do you reinstall DAX? I thought DAX was part of the 1.0.24 beta install and not a separate entity like SmartCAT.0
Just for the heck of it, try a different DAX channel. I have a problem with CH1. But whith Ch 5 it works fine. This is with DXLabs, not FLDigi. 73 Greg AB7R0
George, I did as you said, I opened Device Manager and deleted all DAV references under Sound.then rebooted. Boy has this gotten me in trouble. Now, whenever I reboot the computer I get the error message "DAX has stopped working" Looks like I have a mess. What next: reinstall SmartSDR 1.0.25?0
Dave, George's advice worked for me. After doing his suggestion HRD, in my case works flawlessly.0
I deleted all SmartSDR, CAT and DAX from Control Panel and downloaded a fresh SmartSDR. I made sure there was no remnants Smart anything any where.0
I had the same problem until I UNCHECKED the RIGCAT Box in the Fldidi RIG window. Everything was rebooted and works good. Also, I opened the SmartSDR.xml file in the RIG window. Saved the Fldidi configuration before I rebooted.0
Once I got fldigi settings to work I have not changed them. If I just quit smartcat and then re-start smartcat most of the time this alone will make fldigi start working again. If not, next I toggle DAX on and off. For the last couple of days doing one or both of these have worked. roger0
Dave, you are using com24 for RigCat, however, it should be the com port that is created when you first install SmartCAT. In my case it is com4 as that is the CAT port directly to the radio. To confirm what that port is open SmartCAT and under the main tab look at what is displayed in the "Connect 3rd Party Program to Port". That is the CAT port you want to use in fldigi. Second, as already mentioned you need SmartSDR.xml not PowerSDR.xml. I also use Hardware PTT where I created a PTT port through SmartCAT and assigned RTS as active. I then enabled Hardware PTT in fldigi specifying the lower port number of the pair created for PTT and the I checked "Use separate serial port PTT" and also checked "Use RTS". You can use this or stay with the "CAT command for PTT" in the RigCAT tab in fldigi. As far as what to do since it doesn't work now, I would uninstall SmartSDR and SmartCAT, reboot, and then reinstall both. Hopefully you should be ok after this. Don0
close this one out for me,fldigi working fine with SmartSDR now. The simplest problems can turn out to be a headache.0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
