TRANMIT PROBLEM - NO POWER OUT MORE THAN 2.2 WATTS
James Kennedy-WU5E
need Help yesterday was working DX and digital , now NO power out more than 2.2 watts on any mode. I have check the turning off and on the DAX control panel. I have rebooted the radio still no luck NO Power out. Jim WU5E
did you try to reset the radio ( hold the OK Button down and hit the Power button) Radio will tell you it is reseting. 73's Bret WX7Y0
Did the reset, no luck still only 2.2 watts0
with 2.2 watts into my amp I get 15.6 watt out **** I'm still QRP0
found the issue case closed0
What was the solution?0
Don it was a failure of my Wave Node Watt meter I had be using for 5 years. Mostly running high power though it. I 'm going to get another sensor and try it again.0
Don't you just hate it when that happens!0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
