TRANMIT PROBLEM - NO POWER OUT MORE THAN 2.2 WATTS
James Kennedy-WU5E
Member ✭✭✭
need Help yesterday was working DX and digital , now NO power out more than 2.2 watts on any mode. I have check the turning off and on the DAX control panel. I have rebooted the radio still no luck NO Power out. Jim WU5E
did you try to reset the radio ( hold the OK Button down and hit the Power button) Radio will tell you it is reseting. 73's Bret WX7Y0
Did the reset, no luck still only 2.2 watts0
with 2.2 watts into my amp I get 15.6 watt out **** I'm still QRP0
found the issue case closed0
What was the solution?0
Don it was a failure of my Wave Node Watt meter I had be using for 5 years. Mostly running high power though it. I 'm going to get another sensor and try it again.0
Don't you just hate it when that happens!0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
