CAT has stopped working
DonS
DonS Member ✭✭✭
edited January 2020 in SmartSDR CAT
I cannot get SmartCAT 1.2.2 working. I completely uninstalled CAT, rebooted, reinstalled CAT, and rebooted and still get the "CAT has stopped working" message. Any thoughts? I should note SmartSDR 1.0.2.4 installed without issue.
  • Drax
    Drax Member
    edited December 2013
    My CAT was working now it just crashes with this error: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** FabulaTech.VSPK.FTVSPKException: Critical error! Service is not available. It seems it has not been started successfully or been stopped. at FabulaTech.VSPK.FTVSPKControl.CreateExceptionAndError(FTVSPKErrorCode EC) at FabulaTech.VSPK.FTVSPKControl.EnumPhysical() at Cat.Main.GetAvailablePhysicalPorts() at Cat.Main.lstAvailableRadios_SelectedIndexChanged(Object sender, EventArgs e) at System.Windows.Forms.ListBox.WmReflectCommand(Message& m) at System.Windows.Forms.ListBox.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- Cat Assembly Version: 1.2.2.0 Win32 Version: 1.2.2.0 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/Cat.exe ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- Spring.Core Assembly Version: 1.3.2.40943 Win32 Version: 1.3.2.40943 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/Spring.Core.DLL ---------------------------------------- FlexLib Assembly Version: 1.0.24.34559 Win32 Version: 1.0.24.0 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/FlexLib.DLL ---------------------------------------- AsyncSocketsV2 Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/AsyncSocketsV2.DLL ---------------------------------------- Vita Assembly Version: 1.0.1.34559 Win32 Version: 1.0.1.0 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/Vita.DLL ---------------------------------------- Flex.UiWpfFramework Assembly Version: 1.0.1.34559 Win32 Version: 1.0.1.0 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/Flex.UiWpfFramework.DLL ---------------------------------------- log4net Assembly Version: 1.2.11.0 Win32 Version: 1.2.11.0 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/log4net.DLL ---------------------------------------- Common.Logging Assembly Version: 1.2.0.0 Win32 Version: 1.2.0.0 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/Common.Logging.DLL ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Spring.Aop Assembly Version: 1.3.2.40943 Win32 Version: 1.3.2.40943 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/Spring.Aop.DLL ---------------------------------------- ftvspknet Assembly Version: 5.4.0.0 Win32 Version: 5.4.0.0 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/ftvspknet.DLL ---------------------------------------- Util Assembly Version: 1.0.1.34558 Win32 Version: 1.0.1.0 CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20CAT/Util.DLL ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.34004 built by: FX45W81RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- System.Xml.Linq Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll ---------------------------------------- Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
  • DonS
    DonS Member ✭✭✭
    edited January 2020
    Senior moment. I have an iMAC with Win 7 Pro that I use with the 6700 and I have another PC I use with 3k and 1500 but I also installed SmartSDR and SmartCAT on that PC. Guess I can't have CAT running on both the iMAC and the PC at the same time while they are both on the same network.
  • Tim - W4TME
    edited March 2017
    This error indicates that the virtual port driver did not start and CAT crashed when it could not talk to the driver to get the available virtual com ports. There is no reason why multiple SmartSDR CAT clients can not communicate with the radio at one time. I would go into the service manager and try to manually start the FabulaTech service. If it fails to start, then uninstall CAT and REBOOT the Mac. The re-install SmartSDR CAT.
  • BobT
    BobT Company Adviser
    edited January 2014
    Tim is correct, CAT is limited to one instance on a particular machine but can run simultaneously on multiple machines across the network. The real question is why the virtual port service stopped. BobT
  • Andrew VK5CV
    Andrew VK5CV Member ✭✭
    edited February 2017
    Tim, SmartCAT has stopped working despite numerous restarts. I have uninstalled it and now it will not reinstall as the installer gets "interrupted". One of my security programs (after a ransomware attack) appears to have changed the "virtual serial port kit service" from automatic to manual. What now? Win 8 64bit. Andrew
  • Andrew VK5CV
    Not sure what fixed it but up and running now.
