recording and re transmission
G4BIM
G4BIM Member
Do you intend to make incoming signal recording and re transmission available on SmartSDR, along the lines of that function currently on PowerSDR?
  • Tim - W4TME
    edited March 2017
    The short answer is "yes". It is slated for PowerSDR v1.3 as per the SmartSDR development road map
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    Tim, one question - i guess is very serial, for contests are necessary to record not only reception but also transmission, it can be a part of the recorder functionality ?
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    The ability to record "voice keyer" will be crucial to making this a power contesting machine. The recording and playback should sound EXACTLY the same as the live voice over the mike, and be processed exactly the same way, with filter, EQ, and Compression, even if those things change from band to band. It should sound exactly like the live mike would under the same conditions.
  • Tim - W4TME
    edited December 2016
    I can not comment on the details of any upcoming feature until it is in alpha testing. Sorry. That is company policy as things may change in development process.
  • Greg
    Greg Member ✭✭
    edited November 2013
    Wouldn't it be better to record contest messages with external software such as Audacity? When DAX is available I think it is supposed to look like a soundcard to external apps, so you can record you messages directly. This way they should be in WAV format and easily used for apps such as N1MM. If the 6700 "recorder" saves files as WAV files and they're easily accessible that should be fine. 73 Greg
  • Sergey R5AU
    edited April 2017
    You are right Greg, if this will be not prohibited into the SW, BTW i wonna to use it right now in 1.0.5 but you know you can choose only one input for audio for now.
  • Greg
    Greg Member ✭✭
    I know. I tried to use the line input along with MIC input for SS and could not do it. If that is not fixed soon I think I will probably have to make other considerations for my contest station. 73 Greg
  • Sergey R5AU
    edited April 2017
    Well Greg, sure, this is also put me on hold for participation in long term contests, even N1MM have ability to do this with external HW
  • Mel, K0PFX
    Mel, K0PFX Member ✭✭
    The PowerSDR "record/playback" feature is very useful for digital modes. I use it every day. It is a good "teaching" tool.. nothing better than having a station listen to his "own audio.." This is one but of many reasons why I still use the 5k for digital modes and will continue to do so until the 6k software adds much needed features.
