question about pin out
James Kennedy-WU5E
James Kennedy-WU5E Member ✭✭✭
edited January 2020 in SmartSDR for Windows
Got some peripherals to attach to the FLEX 6500 I'm curious I'm not sure about the ground connections on pin 6, 7, and 8. if those pins are tied to the same ground as Pin #5, or if they are floating The peripherals are the Signalink and KamPlus thanks Jim WU5E
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited November 2017
    From a DC point of view they appear to be tied together. and you're probably be okay assumed they are. How closely they are tied together from an audio/rf point of view, I can not say. AL, K0VM
  • DonS
    DonS Member ✭✭✭
    edited January 2020
    I am using the Navigator and the cable I am using between the Navigator and the Flex 6700 has pins 6,7, and 8 tied together to Audio ground in the Navigator and pin 5 is separate and goes to its own ground pin on the Navigator. Unfortunately I can't tell if they are tied together internally on the Navigator.
