abot half the time the radio opens up in a non-configured mode with no antennas and no sound. Wha
calvin white
The word is PERSISTENCE which has not yet been implemented...0
I've noticed that if my network isn't correctly configured, you may run into this. Does the problem happen when the 6000 is plugged directly into the PC LAN connection?0
This is not normal. There is something going on that requires more in depth investigation. I am converting your question topic to a problem topic and then creating a HelpDesk support ticket so we can figure out what is going on.0
Late experience nearly always points to a network issue, flaky cables, switches, hubs, but can also be related to firewall/antivirus issues also, along with network configuration.0
I think I have a similar issue I can duplicate the issue every time if I do the following: My radio is on an antenna switch, if the 6700 is not switched to the antenna and I power it up (Orange to green) the radio comes up in a state where it receives nothing on any band I switch to. Some times the radio is slow to show on the network as well after this. If the antenna is switched on or no cable is connected to the antenna port it comes up fine. I suspect the antenna switch shorts all port, which are not connect to the radio and this affects the radio in some negative way.0
I should add one more note. After the radio and software are up and running with the antenna switched off, I see no signals on any band with the antenna switched on. The only way to fix this is to shut down the software and Radio and restart with the antenna switched in. All is fine then.0
Watts - Please open a HelpDesk Support ticket for your issue so we can work it with you individually. For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://support.flexradio.com/ Once the support ticket is submitted, a support engineer will be in contact so we can work on the issue. Make sure to include your radio's serial number.0
- 248 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
