Which Mic method do you find has less latency
For those using SSB remote on their own LAN which method of providing Mic audio to the remote radio do you find easiest or has the lowest latency?
1: Using a mic connected via a local Maestro?
2: Using a mic connected via usb to the local operating position PC?
I have all the radio equipment out in the back "He Shed" and use a Morconi unit for CW but have no method yet for SSB.
Thanks for any suggestions
Larry k1UO
    Answer ✓
    I think you'll find that all MIC methods on a SmartLink connection is well less than 100ms. Given that it is on a local Lan, it is likely less than 10ms.
    I would be surprised even at 200ms that typical HF SSB operations would to impacted.
    Is there a problem you are trying to solve or is this just hypothetical?
