FlexLIB question
Can someone please tell me how to get a FlexLIB.dll file? Everything I can find seems to be out of date. This is typical of what I can find:
There are no .dll files in the install location. The file "FlexLIB.dll" is not found anywhere on my computer (W11 Pro). I have downloaded the API library. Other instructions say to use .sln or .csproj files to build the dll but I see no .sln files and one .csproj file in UiWpfFramework. Almost all the files seem to be .cs files.
I have done some c# programming but apparently getting started on programming for the Flex is tough (for me)!
Thanks, Mark K5XH 6600/PGXL/TGXL/AGXL
Hi Mark, Flex now creates the executable with the DLLs incorporated instead of in a separate library. This means that you need to compile the DLLs yourself.
What I do to compile FlexLib with Visual Studio 2022 is the following (if this isn't correct or optimal, someone please let me know):
- Open FlexLib.csproj
- Add project UiWpfFramework.csproj to the solution
- Add project Util.csproj to the solution
- Add project Vita.csproj to the solution
- Build FlexLib
In my application, I add references to the four DLLs (note that the unchecked ones are from older builds)
They then show in the Solution Explorer:
Now I can compile my app using FLexLib.
Thanks for sharing this. I have avoided compiling from source code for the dll files as I never seemed to be able to get them built in the correct order.
Thanks Len!
I was beginning to think that I had picked a bad time to try a little API programming! I have spent many hours working on the .dll problem over the last several days. I about wore out my welcome on ChatGPT and Google searching for a solution but none of them worked. I think most of the info was for the older versions of SmartSDR.
I just tried your method and I now have the dll files! Now I get to see if I can do anything with them.
I wonder why Flex doesn't just add those dll files to their downloads and save dummies like me from wasting a lot of time.
Thanks again Len,
Mark K5XH
Hi Mark, I'm glad you got it working. Good luck with your project!
- 685 The Flea Market
