SmartSDR CAT Version 4.2.20
RKB
RKB Member ✭✭
edited June 24 in SmartSDR CAT
Brand new 8400 and software 4.2.20 software install
Whats happening is:
CAT becomes unresponsive, clicking the Icon for CAT does nothing. To make it become reactive. I have to start a reinstall of SmartSDR 4.2.20, Select Repair, reinstall 84fe.msi and reboot.
Also on the restart ALL of my added CAT settings are lost regardless of the fact they have been saved.
Looking at Device Manager all of my saved Cat Ports are there, BUT are not shown in the SmartSDR CAT popup.
Will be grateful if someone can point me in the right direction
Cheers
Ron
VK4JE
Best Answers
    Answer ✓
    Hi Ron, I would export profiles, then do a factory reset. Before re-importing profiles, try setting up and saving CAT ports again. If it still has the same issue, submit a help desk ticket.
    If that does work, re-import profiles, but leave Preferences unchecked and see if it stays fixed. If it does, then you likely had a corrupt preference file. If re-importing without Preferences causes the issue to return, then you likely have a corrupt profile. You can either rebuild them all, or import them one by one until you figure out which one is the culprit (I have a lot of profiles, so I would check each one rather than rebuild them all).
    Answer ✓
    Glad you got it working Ron!
  • MarkS
    MarkS Member ✭✭
    If you click on the “Station” pulldown next to your call do you see other choices? I’ve been using CAT with SmartSDR and Aether and I have two different choices (using Windows 11). Depending on which SDR program I’m using, it is one or the other choice to get the expected settings. The other choice is empty. Mark - wd9jen.
  • RKB
    RKB Member ✭✭
    Hi Mark,
    No, I only have the callsign and no additional 'Pull Down"
  • RKB
    RKB Member ✭✭
    Hello Len,
    Did as you suggested with the addition step of placing the SmartSDR software onto it's own NUC, works fine now.
    Thankyou
    Cheers
    Ron
