I am no luck at all since upgrade. Does anyone use Verizon internet w/ipad?
While connected to same router all is well. When I try from the RV nothing works.
Any help would be appreciated.
    You will need to explain a bit more about your setup. Where is the radio? Where is the user operating from.
    Has remote ever worked? If not, it sounds like you did not complete the radio registration where you have to use a PTT switch to autheticate you actually are in control of the radio. Did you get a 'green' test light?
    Reread Chapter 9 of the SmartSDR User guide and follow through each step just to make sure you didn't miss anything.
  • John KB4DU
    John KB4DU ✭✭✭✭
    Does the iPad connect and operate when on the same local lan as the radio?
