Possible Cause for Odd HIGH SWR ?
I am intrigued and wonder if anyone has any guesses . I was playing with AetherSDR the other night , setting TX audio . Earlier I had been on 20M having a QSO or two and all was well . Immediately after adjusting TX audio in AetherSDR I made a test transmission and noticed my SWR on the EFHW was sky high . I booted SmartSDR for Mac, same issue , SWR as high as the meter would go , even when clicking on "tune" .
I went through the usual steps that I could do indoors (it was dark outside ). I checked coax connector, reseated it. Removed the external antenna from the situation and connected coax directly to the 8400 . rebooted radio, rebooted computer and AetherSDR several times. STILL sky high SWR. Let radio cool off for 15 minutes, still same problem. I concluded I need to leave for morning to check the antenna outdoors . I currently don't have a second antenna to do an A/B test .
Next morning before checking outdoors I turned on the Flex 8400 booted AetherSDR and SWR was good , as good as it always is . I operated a little throughout the day , no problems . Later that night I returned to AetherSDR and tweaked the audio channel **** . Upon doing a test transmission I AGAIN got an immediately sky high SWR , same with SmartSDR for Mac . Next morning all was fine with the SWR. It has been fine since, but I"ve not messed with TX audio since .
I wondered about moisture at the EFHW's transformer but it has rained heavily for a few hours each day since this happened and no SWR problems . Today we have 60 MPH wind gusts and SWR is as good as it is usually . So, anyone have any guesses what would cause this phenomenum?
Andy K3UK
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Andy,
I would recommend testing into a dummy load first to see if you can isolate the issue to the antenna system or the radio/software side. If SWR is normal into the dummy load, the antenna system is the culprit. Also worth noting: were all the problem occurrences on the same band? The pattern you're describing, where it resolves overnight without any physical changes, is a classic clue.
Now, about EFHW antennas. They require some care and feeding, and the sales pitch often glosses over the details.
End-fed half-wave antennas are voltage-fed at a high-impedance point, typically 2,000 to 5,000 ohms, which the matching transformer steps down to 50 ohms. That transformer is doing a lot of work, and it has an Achilles heel: it needs a small amount of current to flow somewhere on the "cold" side of the feedpoint to complete the circuit. Without it, the feedline itself becomes part of the antenna, and common mode current starts flowing back down your coax into the shack.
That's where your symptoms get interesting. RF in the shack can do all kinds of mischief, including corrupting audio streams, triggering software behavior, and producing reflected power readings that look like a sky-high SWR but are actually common mode current being sensed by the radio's protection circuitry, not a true impedance mismatch at the antenna.
A few things to address this:
Choke at the radio end. You want a common mode choke at or very near the radio, using a high-permeability core like Mix 31 or Mix 43. This is your first line of defense against RF coming back into the shack on the outside of the coax shield.
Counterpoise or choke at the feedpoint. The EFHW matching transformer wants to see a low-impedance path to ground at the feedpoint. You can provide this either with a short counterpoise wire (1/20 wavelength or so is often enough) or with a choke on the feedline at least 1/4 wavelength down from the feedpoint. Without one of these, the transformer is "floating" and the antenna system becomes very sensitive to nearby objects, feedline routing, and what your software is doing with the transmitter.
Matching transformer quality matters. Some EFHW transformers on the market are wound on undersized or inappropriate cores. Under sustained TX load they can saturate, shift impedance, and in extreme cases arc internally. If the transformer gets warm after a transmission, it's working too hard. Check the SWR both at the start of a transmission and after a few seconds, since a failing transformer will often show a clean SWR at the start that climbs as the core heats.
The overnight recovery is also consistent with this picture. Thermal effects in the transformer core, or RF-induced charge settling on nearby objects, can resolve themselves given a few hours. Moisture at the feedpoint transformer can also shift SWR but typically gets worse with sustained rain rather than better, so I'd move that lower on the suspect list. And, were you on the same band?
Start with the dummy load test, then audit your choke situation at both ends of the feedline. That should point you at the root cause.
Thanks Mike . Your comments remind me that a few weeks ago I removed my Balun Designs II5U 1:1 isolation suppression balun from the circuit to use with another antenna I am building . I can put it back in line since I am a few days from putting the new antenna up . I did wonder about the transformer overheating but since things rectified I did not address it properly .
I will get the dummy load and 1:1 choke involved and do more testing . The 49:1 transformer is a few years old and home-brewed by a local ham , so perhaps it is time to replace .
ANDY K3UK
Many of these transformers are under-sized. May work well on 5 watts QRP, but subject to overheating with sustained use at higher power. Even a 1KW rated may overheat or fail with sustained use, like contesting.
- 684 The Flea Market
